Baja db30 axle set
hi I’m new to these forums but I been looking for a set of axles for a doodle bug db30 front and rear lost mine and no luck finding some online so wondering if anyone has a some willing to sell.
The set from a Coleman CT100U might be the same. They're available on the Coleman Powersports site. You'll need to do some measuring to make sure they'll work though.
Addicted 2 Minis
If you are using an actual Baja DB30 front rim, the spacers are 54mm and 83mm, the original wheel hubs are offset. Most retailers offer rims that will fit but what they don't tell you is, the offset is more than likely different and will require new spacers. Motovox, Coleman, Moster Moto and Mega Moto wheels will all pretty much interchange with each other but the wheel spacing, sprocket hubs and brake hubs are not always in the same location.
Similar problem for me. I took off the rear wheel to replace the tire that was chewed up. I kept the rear axle safe with castle nut but i lost the spacers. I found one spacer. I have a 1st gen baja DB30. Not the one with the curved top bars and seat, I have the one that looks like a fox doodlebug. What are the dimensions of all the spacers for the real axle/wheel assembly? I can machine stuff. If I just knew the measurements it would save me trial and error time on figuring out what works best in there. Can you tell me the dimensions of the spacers? I have oem rims and 145 Wanda tires. Thanks
