Greetings all:
In my spare time over the last 1.5 + years I have been slowly putting together a Bonanza 1400T. This would not be possible without your generosity of sharing experiences-both good and bad for a novice such as myself to learn from.
I started with a bare frame that I bought locally which had been previously powdered coated. The great majority of all the other parts were obtained from you.....all the fine folks on this forum. Not shown in the photo's is a reproduction gas tank, and seat ready to go. The Tecumseh H50 is dated 1971 which I re-ringed while also adding a lighting coil.
At this point I am mocking up the Comet manual 2 speed, attempting to size the dual drive chains. The sprocket sizes on this manual unit are a 24 t and 12 t.
My question is:
Does anyone know what Comet? or other brand dual sprocket, engine driven clutch was oem that I should be looking for? I was mocking this up with a currently available max torque dual sprocket 12t clutch. The dual 12t will not properly tension both chains. The original must be an oddball wherein 1 sprocket is a different size from the other.
Note for reference, I do have an original chain guard for this application. Measurements seem to indicate that the center to center shaft distance falls to c. 8.25 inches. Sorry, that photo attached is upside down.
Thank you all. If anyone has the necessary part, or advice, please let me know.
Thanks in advance,
Bernie
My question is:
Thanks in advance,
Bernie
