Been vacant for a year point five ..
#21
Nice Job!!! My only suggestion would be to use the extra spool for a backscratcher. Sweet little set-up. Have you had a chance to get it dirty yet?
Good eye ! The extra spool will be used mainly for another set of powered wheels to transverse back and forth...Stilll in designing phase though..Tracks or tires????
#22
Mine is an uneducated guess...but my thought is that traction will be critical when using the device, so I'd think a track or tracks would be beneficial for transversing.
#25
From my experience, weight is the most critical element to transfer/leverage power to ground. So either weigh that tongue down when in use or anchor it
The tongue is only for pulling machine close to job then drops off with 2 hitch pins. The small caster wheel has a small hole in triangle plate that I can link a small t handle to it for dragging machine around to position. You dig with this with the 2 fold out/Telescopic "Kickstand" legs to the rear and cinches the machine fairly well even if it rears up on them from aggressive digging motion. 20220712_205542.jpg 20220712_205521.jpg 20221022_162721.jpg 20220806_202838.jpg
If your outriggers don't bleed off they will help but trust me that when the bucket bites into hard dirt it will lift the backend up. I have a Branson 2910i with a sub frame backhoe and it happens to me a lot. My outriggers do bleed down which is very annoying, but I am somewhere around 4000#s, and it will lift the front end up. I am really impressed by that little machine. You should be proud.
Fred
