I have a new 212 Hemi never run yet. It will sit till I get all of the parts found to get what I want to put into it. It will go onto a go cart a copy of one the boys had when they were small. Now married with kids of their own. The parts list will be new billet flywheel billet rod not sure which cam and lifters and stiffer springs and push rods to use with the Hemi head. I would like to put in a 28mm and 26mm SS valves into the head. The Rod and piston might be longer rod with a mill to fit piston. That I would like to try to round off to fit into the Hemi head. If needed I might have to cut valve reliefs into the piston. I figure the bigger valves will need less lift to flow well. I have a friend who runs a sled shop so I can get a 22mm carb from him or the size I will need. And I was thinking of putting some reeds between the carb and engine to help with air flow. Ok has anyone done anything like this yet? So What is the good and bad of what I have laid out so far? I have no idea what HP it would have or RPMs it will turn I would like to keep it about 7000 RPMs or so. Lets hear what where I would be going wrong or right?
