Make sure he's starting it correctly. With the compression release all it takes is a little tug to start. If he's not on the compression release it will do just that. From the manual, Pull the Starter Handle gently until resistance is felt. Allow Cable to retract fully
and then pull it quickly. Repeat until the engine starts.
Also as a side note, if the valve lash is not correct you can override the compression release and it's a bugger to start.
As for the plug, that's the first mod that should be done. The stock plug is doo doo.
