Hey stephen, i've got a 7 speed shifter build that im trying to make faster, but i need a flywheel and a rod for a 79cc Predator. How much might that cost if i sent my parts to you for copies?
i've bypassed my gov, which is why i need these items. would like to have all other parts before i get the valve springs, that way I don't have to worry as much. and before anyone says anything about my bypassing the governor without the performance parts, i did my research to find out what can go wrong, so i've been kinda babying it, only using max float rpms during acceleration. and, because i simply bypassed it rather than removing it, i can always put the stock throttle arm onto the gov connector. also, really the only reason i bypassed the governor in the first place without the parts is because i needed to get up to speed faster, and higher rpms seemed the best way to do that without drastically lowering my gear ratios.
