ok i have a stock db30. everything is hooked up correctly, i have good compression, the carb is set to initial factory settings. it will only rev up at have choke but idles fine at full choke when cold and will idle back down correctly when at half choke once warmed up. DONT ANSWER IF YOU DID NOT READ THE PREVIOUS SENTANCES. PLEASE, it only makes you sound, well, dee, dee, dee. But for everyone that did read here is my problem. once warmed up, I can give it throttle at the handle and it will only rev up halfway, producing only half power and it will lope when i hold the throttle steady at any rpm.. But if i move the throttle that is directly connected to the top of the carb the blitz will go full throttle without skipping loping or any irregularities. Now, for the question. Why is this happening? Please no because you didnt clone it responses. I need real answers from smart people. And for you clone lovers. sorry to be a hater but I've had better results with flatheaded b&s motors than any clones. the blitzs motor does not even hit half way to its max rpm. all the cable and carb adjustments only change it barely. yes theres a difference but not enough to correct the problem. can anyone that knows, please help me correct my problem.? i understand these motors are under powered but that is not the problem. something has to be out of wack or im missing something cuz theres not any issues if i were to hook the throttle cable right to the carb. wich i know is a nono because bypassing is bad. could my throttle springs be hooked up incorrectly? does anyone have a pic of correctly hooked up springs and or videos of how to check and fix my motor before i get frustrated. im trying to sell it but noone wants a half running db30 please help me get my db30 running back to its correct way.
