Bonanza BC1300sh bolts question
I am building a Bonanza BC1300SH from scratch. I am in need of most of the bolts for assembly. Can anyone tell me the exact bolt sizes for the following?
Neck Bolt
Axel Bolts
Rear shock bolts (top and bottom)
Fender bolts
Hodaka motor mount bolts (the bolts that hold the mounts to the frame)
Rear wheel (go power) assembly bolts. I read somewhere that because of the sprocket the rear ones are longer than the one for the front wheels.
Also, if anyone has any nos bolts for the above I would be interested in purchasing them.
Thanks for any help.
trinik7597
I might have some og axle's and stuff laying around ... I will take a look after work for ya .
Go power slotted 1-3/4" phillister head (front and back the same), axles 7-5/8" x5/8"-18 w stover locknut, shock bolts 1.5" and 2.5" x 5/16"-18. I'll get the hodaka and neck bolt later. All bonanza hardware is clear or some say white cad plated except the kickstand is zinc and the bendix brake is gold cad. A place called nutty bolts is the only place that has close to the correct style stover nut but they are gold cad. I got all my original and replacements cad plated. I still need to have some done if you want me to get yours plated I'm in Akron too. I have some extra of the large hex 5/16"-18 eyebolt nuts that have been cad plated. I'm finishing up a 1300sh now too. Need to put the cables, chains, electric and carb on still.
