bonanza fork rebuild
fork looks bent could be hanging up
Definitely need to get those forks straitened out.
If I was doing it, I would secure the triple trees in a big vise or press ect. with 2 by 4's or what ever is suitable for wood.,, & then with moving around medium heat where they are bent,, use a'' long'' pipe in the forks about up to the bends to straiten.
Like Karen said,,
you can probably get boots pretty easy that would fit.
I
so i got the forks apart. springs are still good inside the inner tube the spring slides into is bent. gonna have my friend josh weld new tube. the wheels are brittle and crumbling apart. need new rims. never easy projects 4 me
