Bonanza MX1510 build
I recently bought a Bonanza MX1510 that I am going to rebuild. Of course it is missing parts that I need help with. The major things right now are the rear wheel and the seat base.
I see Azusa still sells the 8” spinner wheels, but I have not found a rear sprocket/ brake drum assembly. How many teeth were on the rear sprocket? Also what size sprockets were on the jack shaft? I will most likely use Hodaka power.
Does anyone have a fiberglass seat base or whole seat that they can part with?
I see new 12” rear shocks for sale, does anyone have any recommendations? They are available with different spring rates and I’m not sure what Bonanza used.
Good luck! I have an extra wheel…and one sebac shock…tank and seat will break you…best bet buy a tank from @125ccCrazy ….
No brake…brand new if using for rear it’ll need drilled out for brake drum…easy process…
60 tooth usually but 72 also I believe on the 1510…usually on eBay etc occasionally $80-200….there is a guy posting on here from ny thst boosts of a plethora of. Bonanza parts may want to contact him first?
The back sprocket looks small in pictures I’ve seen, it’s just barely larger than the 5” brake. I guess that could be 60 tooth or smaller. IMG_3917.jpeg
