Your swing arms should be below what your photo shows, with the shocks installed. So they never set parallel to the ground, not even on full compression doing sweet jumps.
Not knowing correct this and correct that on your machine, I can say 100% of the time I am having to make bushings for shocks on everything I've over restored with a shock. I do it to compensate for aftermarket, or different shocks, or engineering problems. I have never seen a minibike swing arm that was perfect. Even motorcycle swingarms tend to be tweaked if you put them on a rack and get precision measuing equipment on them.
I have rewelded many minibike swing arms because of this reason. They are not precision devices at all. I have also turned bronze bushings for swing arms, including Bonanza, because the gap between the swing arm and the jack shaft plate was excessive, not even on each side, etc.
Also, there are different swing arms. Front peg bikes should be 8 1/4, mid peg is 8 3/4. (According to Evil Ed)
