So I decided that I would like to add tail, brake and headlight to my MTD Trail Flite.
Bike has drum brakes with cables. I bought a switch that will work, and had a plan to make it all work.
Plan was to weld a small bracket to the underside of the mounted part of the brake handle to mount the switch, then another small tab on the hinged handle part that would contact the switch.
I found a washer and threaded it to match the M8-1.0 threads on the switch, then ground a flat spot on the washer to weld to the mounted part of the handle.
I thought I was a genius until I tried to TIG weld the washer to it. Even though the metal is magnetic, it must be cast because the metal would not really puddle at all and I was unsuccessful at welding it. I do have some silicon bronze filler rod and I might try TIG braising the washer on.
So for any other members who try this, don’t waste your time trying to weld on cast brake handles. I wasted a couple hours trying it.
If I have to I can make a bracket that will thread in, but I have to go back to the drawing board on that one.
I’ll try he brazing and see how that goes.
