hit it on the thicker ears and see what you can do to hold the flywheel...and not by the fins. Once the ratchet is off, use a screwdriver to pry against the case and flywheel and give it a light tap on the end of the crank. No too hard or you will mess it up! A brass hammer is your friend here
