That coil on the left has an air gap armature above the top of the coil. Exclusive to B&S coils, this gap causes a stronger spark with longer duration. Confirm that all the metal-to-metal surfaces are clean bare metal, coil wire is not touching a ground surface and points open at the correct flywheel position. If this won't make a good hot spark, the condenser is probably defective.
