BT200X Help
Brought home a BT200X tonight and within 10 minutes my son put it into a cattle fence and it landed somewhat on the right side sort of upside down. Long story short, he’s fine but I can’t get the thing to run for more than a second with starter fluid. At first it wouldn’t even pull when trying to start it. I removed the air filter, it was wet with oil, and the spark plug and there was oil spewing out of the spark plug hole when I pulled the starter. I pulled the starter until no more oil came out, cleaned the plug and left the filter off. I tried starting it for probably 30 minutes and can only get it to run a second or so with starter fluid? Any suggestions?
Minimichael
Take off the blower cover and inspect the flywheel for a sheared key. Tighten down or otherwise ensure the carb and intake remain airtight at all gasket faces. Check that the choke's not damaged and engaged.
Thanks for the welcome and ideas! I tore into it this morning, pulled the bowl off the carburetor (it was full of oil), cleaned the carburetor, put in a new spark plug, and changed the oil. After I put everything back together it started up on the first pull! Looking forward to seeing my boys wrench on this thing and tear around on it!
DaddyJohn
I was going to mention that these things can get a carb full of oil when the engine gets turned over or laid on its side, but it looks like you discovered this quickly. Nice job!
