hemi predator refreshed new rings and rod bearings only run time for breakin/tuning.
specs:
-212cc block low oil / gov removed
-NR 230-0611 cam 6500+ rpm
-22lb springs
-chromoly pushrods
-ported head / milled .060"
.010" gasket
-ARC billet rod 3.308
-mikuni 22mm carb kit brand new
will include:
complete stock carb
extra jets for mikuni
black factory gas tank
throttle cable
kart header that will need re-welding
black fan shroud / pull start
motor needs nothing add oil/gas and go
ARC flywheel was removed for another application stock flywheel in place. add 32* flywheel highly recommended
$450 SHIPPED
-Also have billet NR 1.2 roller rockers with correct length 5.160 pushrods I''ll throw in for an extra $100 or
$75 shipped for just rockers
-knock off mikuni 22mm carb #95 jet (carb only) $20 shipped
PM ME for any questions thanks!
Located in springfield VA
specs:
-22lb springs
-chromoly pushrods
.010" gasket
will include:
complete stock carb
throttle cable
$450 SHIPPED
