All these parts are for Tilloston & Predator 212cc and more engines electric start or pull start engines. Tilloston 212E or EE stock carburetor, Tilloston PK1-B carburetor, new governor spring, Complete governor assembly & plastic (nylon) governor gear, steel rod & washers, complete linkage assembly that goes on the top of the head and carb., Complete stage 1 performance kit it shows all the parts that come with this stage 1 performance kit, one new throttle cable & one used throttle cable the length for these throttle cable is 49.5", Tilloston 212E or EE muffler, air filter assemblies, one carbon tank, cast iron flywheel for electric start but it will work on non electric starter, black plastic cooling fan it goes by the flywheel, The headlight / electric start coil and dual charging coils there 100%, stock piston rod with the rod cap bots intact, stock camshaft, Brand new chain 51 + 2 links of #420 chain, Belt CVS 30 series drive belt #203590 length is 38.32"
& positive & negative battery cables, 3 speed adjustment switch 12V for 7/8” handle bars on-off-on control switch it’s for headlight. These parts go on Tilloston, Predator and different small engines. If you need a video I have some. Sale price $250. O.B.O.
