I have a 3hp briggs IC engine with a bearing on the crankshaft. How do I set the cam timing without taking that bearing off ? there is a punch mark on the crank counter weight . The bearing is pressed on the crank and I don't want to risk breaking it trying to get it off. Also what does that little lever do on the cam ? is that a valve rotator or a compression release ? it does have a bearing on the exhaust valve spring. I was going to do the port and eyebrow work but a 3 horse engine won't pick up that much to make it worth while. It looks like the crank and cam have to go back into the case together because if I put the crank in first the bearing is in the way to get the cam in.
