/If you can see from the pics the Exhaust lobe has very light scratches, is this normal cam ware? Running 22lb valve springs with stock rockers. Bp2 Cam and the suggested valve spring is 26lb. Had the cam for few months now so could have 15 hours on it. Thanks.
what does the lifter look like?
I am not sure I'd be concerned about where the lifter rides on the base circle, I'd be more concerned about what the lift side of the lobe looks like. Post a pick of both lifters if you can
