Well there should be no less the 1/2" up and down play at mid chain between clutch and sprocket. If there is no play or less that 1/2" it can cause premature wear on all parts. Including clutch and bell housing, sprocket, and chain. Possibly even wear out your engine bearing, which would cause ciaos internally, crank, rod, then piston. So yah don't run it tight.
