Solder the area you want to cut, about and inch in either direction of the intended location. A quick couple passes with some sand paper will eliminate any bulges from the solder. Use quality, sharp cutting pliers to make a nice clean cut. Your cable is now ready for whatever use you intended. No frays, no strays.
