im sorry if this question is dead obvious. my bike had its carb started leaking a couple weeks ago,
i checked the float, it works fine.
i put a new o ring between the bowl and the aluminum, still leaks.
then i put in a o ring where the lower bolt was (it looks to be leaking from there) still leaks, but very slowly ( like a drop a minute)
after about 3 hours i got to a point where the carb will leak only if i shake the bike (not sure if this is normal, ive never worked on carbs before)
the bike runs fine but im not a fan of fuel leaking near a hot exhaust....
any help would be appreciated!
