CAT Eliminator clutch cover brackets. Exact Reproduction. With Stainless Steel screwa
$30.00 for the pair includes shipping to lower 48 states. Exact reproduction of the Cat Eliminator 1 hole and 2 hole brackets. Sure can be used for other Cat models as well. They are a very correct repro. Tapped and comes with 3 Stainless Steel screws not show in photo. These are as good as it gets.
Hello,
I believe they should work since all the clutch guards were basically the same looking but some had 2 separate 1 hole brackets and some most had the 1 hole and 2 hole brackets. I have plenty of each and they are perfect repro.
As long as they are going on a h25, h30, H35 or hs40 yes they will work. But your using the correct guard than technically you should only need one I believe.
