Although I've only ridden my Goat a few times, it's obvious that the overall drive ratio needs some modification. It has a (presumably) 7 hp Briggs, a (presumably) series 40 Comet Torque Converter, and two jack shafts back to the rear wheel.
The Comet site says that a series 40 has a range from ~ 2.33-1 to 1-1. The reduction between the 1st & 2nd jack shafts is 15-35 (2.33-1), and the reduction between the 2nd jack shaft to the rear wheel is 11-40 (3.64-1). I wrapped a tape measure around the rear tire & measured a little over 51" - I'll round this down to 50 to make calculations easier. It was interesting to note that the original ratios incorporated the "hunting tooth" principal, whereas the tooth counts do not divide evenly. This design concept ensures that the sprocket teeth do not mate up with the same place on the chain on a regular basis, thereby spreading the wear over the whole system.
Using my calculator, that's 8.48-1 from the T/C driven pulley to the rear wheel. Coupling that with the T/C's 2.33 reduction yields 19.77-1...yea, it will pull stumps! Using an engine governed speed of 3600 rpm, the low ratio (high numerically) yields 8.8 MPH, and the high ratio a whopping 20.5 MPH. Given that I'm only planning on riding this mini off road I don't want to gear it for Bonneville, but certainly I can step it up some. It's a big & heavy machine with no suspension, but it's a 7 hp or thereabouts for goodness sake!
The Goat's sprockets are not keyed onto the shafts; rather, they are welded on. It does appear that the driven pulley is not welded onto the first shaft though, so it may be easier to just replace the shaft with a keyed shaft vice grinding off the old sprocket and welding on a new. And that way I can easily return it to the original configuration.
I was thinking of changing the 1st to 2nd jack shaft reduction to something like 24-35. Plugging those numbers into the equation yields 13.8 MPH for low & 32.1 for high. Or perhaps a bit taller; a 26-35 ratio yields 14.9/34.8 MPH and a 28-35 yields 16.1/37.5 MPH. Now I'm starting to think about a hi/low range gearbox!
All insights and opinions appreciated - thanks!
Joe in St Louis
Joe in St Louis
