Check out my vid!!!
Ratbike
My boys take my mini for a spin!!
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/N5fEx_VksxU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/N5fEx_VksxU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
minidragbike
Supporting Speed Nut!
Yeah I want to know how fast as well
That little bike seems to get up and go real easy with him on it.
The gokart looks to have a tecumseh OHV on it.
Ratbike
its actually a three wheeler with a 5.5 Tech...The mini tops out at 51mph with the wheel up or down...Motor is a package 1 with a billet rod, does extremely well for the money...:thumbsup:
LOL! Wind noise or what? What comes with the package 1? springs? carb? Cam?
Is that an Asuza frame? Keep em coming, need a vid of that bronc.. :thumbsup:
Ratbike
Pkg 1 comes with air cleaner{tunnel ram adapter},18lb. springs,jet,header,gov.removed,advanced timing key,and small fan. 9.2 hp @ 4500, 12.3 ft lb torque @ 4200 rpm....still gotta work on the bronc vid...maybe something climbing hills...:thumbsup: LOL!!!
Thanks for the info. :thumbsup: Still has the non adjust carb?
Need more vids! You have a nice long road to air things out. :thumbsup:
Ratbike
good vid, was the 3 wheeler a t555 ?:thumbsup::thumbsup:
Not sure...pcked it up on the road a few years ago and someone had done some welding and reconstruction on it, it has a center spring suspension which I have never seen before:thumbsup:
Ratbike
That sounds about right on the speed.
What gearing are you running?
The motor should be able to run all day long no problem.
12 toothup front and 60 back ,13" slick. Pretty exciting on gravel roads!I have 40 tooth but didnt want to burn clutches as we are in the country. i'm pretty sure it will pull it though. I estimate top rpm around 5500...any thoughts on the 40?:scooter:
