Cheeftah BC1000 custom drag bike (incomplete) Riverside, CA
I believe this is a Cheeftah BC1000 frame originally. Ive done alot of work to it , it is very straight. The engine is a 6.5 Jaindong, or Honda copy, carb is rebuilt (not pictured) Engine is virgin stock. Bike is geared for a good top end (60 or better depending on engine power) front axle is also foot pegs, 10.75" total/2.75 at each side.
New: engine plate, #41 sprocket, tires (6" rear, 4" front), good #41 clutch
Needs: throttle & grips, seat, chain, disc brake calliper and hand lever.
I may have a caliper but cant guarantee) the brake disc is about 3/16 thick.
The rim will accept a larger diameter disc. Buyer could add a clutch/band brake if u like.
possibly a gas tank (i do have a tank for this motor but just needs cleaning and a gas cap.
I may paint it Krylon "Expresso" which is a dark coffee brown.
This bike is balanced, meaning the motor is centered, so are the wheels.
Forks can adjust downward/lower than you see on this pic. The front end will lift as well with that adjustment. Handle bars can adjust to any angle. This bike is pretty well worked out, has been fitted up with a chain to check fitments etc.
Asking $200
(951)780-7276 Lee (323)632-4731
