Been looking around and a lot of questions involving camshaft installation so why not make a thread
Step 1
Remove your engine and set it in a clear area
Step 2
Remove spark plug
Step 3
Remove engine oil drain plug
Step 4
Remove the fan shroud and starter
Step 5
Remove your valve cover
Step 6
Loosen your rocker arms
Step 7
Tilt engine towards the flywheel Remove your side cover
Step 8
Align camshaft and crankshaft marks
Step 9
Remove camshaft by pulling with your fingers
Step 10
Check your lifters they can fall out
Step 11
Apply assembly lube to camshaft bearings and cam lobes Check clearance of the new camshaft and the block and the clearance between
The counterweights of the crankshaft
And camshaft
Step 12
Install side cover
Step 13
Set your valve lash
Engine at TDC lash set to .003" or .08mm Now rotate the flywheel 720° by hand does anything bind (valve springs, piston to valve clearance)
{ if there are enough guys/girls wanting a thread on checking piston to valve clearance I can do a thread}
Step 14
Install valve cover
Step 15
Add engine oil
Step 16
Install blower cover and starter
Step 18
Install spark plug
Sent from my iPhone using Mores code
Step 1
Step 2
Remove spark plug
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
And camshaft
Step 12
Install side cover
Step 13
Set your valve lash
Step 14
Install valve cover
Step 15
Add engine oil
Step 16
Step 18
Install spark plug
