clone exaust studs fell out!
dirt
New Member
hi my yellow clone exaust studs fell out! i was riding and then the exaust was gone. i tried to remove the studs fron a old parts motor, pb buster and vice grips stripped them. should i mail order new studs for $2.00 and $10.95 shipping or get metric 1" BOLTS at lowes?
Id get bolts ....just cut em off and dress the ends with a file or bench grinder.....
To install or remove them,,,,,use a double nut jammed against each other on the threads ...then you can get at it with a wrench.....
Vise grips are second only to a hammer in what they can destroy....I use them every day (tin knocker)
dirt
New Member
m8 1.25 hex heads
m8 1.25 hex heads pulled out. i used red thread lock. :censure: after 30 min I lost one bolt ant the other was 40% out.
drilling ok how, where ,with what? i have harbor freight titanuim drill bits. do i use a drill press or drill on engine? wire size? copper? :confused:
thanks
engine is a yellow dupor with their upgrades.
JamnJM
New Member
Get metric set screws that size and length and then use an allen wrench to install or remove them later on if needed...:thumbsup:
