I replaced the throttle and throttle cable on my minibike yesterday since the last time the bike was rode the throttle stuck wide open and was ripped off of the handle bar when attempting to shut the bike off. The bike sat for about a year since then. Ever since I got the throttle hooked up the bike has been near impossible to start. The majority of the time the bike starts it runs at a very low rpm for a few seconds before dying. Any amount of throttle change or choke change instantly kills the bike. The two times I was able to get it to run at a normal rpm it would run only about 10 seconds.
So today I took it to work with me and worked on it when I wasn't busy. I drained the tank and carb and changed the oil. It still wouldn't start and the few times it did it ran at a very low rpm. So I then reset the valve lash and tried starting again with no luck. Then reset the coil gap. I was able to get it started twice out of a dozen times trying and it ran fine when I was giving it slight throttle. As soon as I let off it would die.
I also cleaned the carb as best as I could since I was unable to remove the jet and emulsion tube. I also drilled the idle jet out with a number 76 bit on a jet out of another carb and placed it in the carb.
Engine specs are:
stock crankshaft
billet rod
flat top piston
billet flywheel
Blackmamba jr. cam
PORTED/MILLED 18CC HONDA HEAD: 27MM/25MM VALVES, SPRINGS, RETAINERS, LOCKS
Item# store_item-121797 , SELECT AMOUNT YOU WANT MILLED OFF: NO MILLING
hi flow air filter and exhaust
coil replaced when engine was rebuilt
140 emulsion tube and I believe a .038 jet.
Im going to try and take the carb apart and clean it again since I now have access to the proper screwdriver.
Sorry for the wall of text.
Engine specs are:
stock crankshaft
billet rod
flat top piston
billet flywheel
Blackmamba jr. cam
