Clutch for a 9/16 shaft?
Good Luck bryce...If you find one ...It ain't going to be cheap, usually they run around $200.00 . You might PM manchester1 I think she had one built by the good folks at Max Torque.
Yes contact Max Torque. Great company to deal with. The owner will make you one.:bowdown: You can contact them through there web site. :thumbsup:
Max-Torque will make one up. All we need to know is LH or RH threads, if it is a woodruff key (half moon), or full length keyway, verify what keyway width is, most are 1/8" but I have had people send me crank and it was 3/16". Lastly need to know what size sprocket you want to run from 9 tooth up to 25 teeth in the #35 chain. We can make them in #41 but then you are limited to a 10 tooth, a 13 or 14 tooth. Engagement will be 2,500 rpm or 3,000.
Jim Donovan
