My new Max Torque (#35, 3/4") clutch has some play along the crankshaft of a new 6.5HP Lifan engine I just bought from HF. Has anyone seen this before? I guess I'll look for a washer/spacer to keep the clutch from slopping back and forth along the shaft.
Put a washer on the shaft, then use a good one to hold it on. Don't use side set screws on a tapped shaft, those are only for untapped shafts with no bolt.
