Coleman 165 jack shaft bearings
jspbtown
Can anyone offer some help on locating the jack shaft bearings for the Coleman 165? I thought they were 1 3/8" OD nd 5/8" ID but the ID seems too small. It looks more like 11/16" (or 17mm) ID.
I can't seem to find such a thing.
I found them at a car place.
Turns out they were the same as a air compressor bearing..
18 dollars apiece.
But I hornswaggled the guy and gotten for 1.98 each...
DaddyJohn
You can usually get bearings like this for a few bucks at Fastenal if you need to get it locally.
If you can wait a little while, they're super cheap on eBay or Amazon.
Just be sure to pry off the seal and add a bit more grease before use.
The cheaper bearings tend to not have much grease as delivered...
