A couple months ago, I purchased a new CT200U. The bike was brought home and completely disassembled. A couple of Hemi Predator engines had been purchased previously, as I looked for a good deal on a bike. My plan was to make a nice minibike that I can use for hunting and hauling on my property. It needs to have enough power to climb steep hills and also be stable enough not flip over on me. Parts have been purchased and reassembly has now started. A CL-1 cam still needs to be picked up for the Hemi and I may spring for a stainless steel valve kit. We’ll see.
The Predator gets a complete rebuild with governor removal, ARC billet rod, ARC flywheel, 18lb valve springs, CT200 pipe, muffler, and a Mikuni intake and carb. The engine will also have an ARC billet side cover with both side cover and head studs. A CVT has been added and the engine is rubber mounted in the frame. This thing should rock.
Making the bike more stable was very important. To do this, the frame was cut a lengthened 12” with 7/8” steel tubing. Two more sections of 7/8” steel tubing will strengthen the frame at key points front and rear. Some 5/8” tubing will be plug welded and used to index the front and rear frame sections. Some decent weather would be nice to get this finished up.
The photo shows a Kohler 2000 Series engine in place of the Hemi. A jackshaft will be used to make it possible to use several different engines in this bike. You may notice that the front end has been modified to use the same drum brake as the rear. I’m currently looking for options for a front suspension and I may use a suspension tractor seat.
Please comment and offer any suggestions. It would be appreciated.
SamM
SamM
