Coleman CT200U Disc Brake Setup?
Jockey
New Member
Has anyone done a disc brake conversion to the Coleman CT200U? The rear drum brake can not keep up with a bike that runs 72 MPH. I was hoping to add a disc brake to the front if only the rear is an option that'll work too.
Jockey
New Member
I took another rear rim cut the sprocket flange with the hub and bearing sleeved it and welded it on the drum side for a disk.
Do you have a pic so I can see? I thought about maybe taking a front rim, machining the axle tube down shorter and welding a flange to it and making a caliper bracket on the fork for front brakes. Unless they make a rear 8" rim set up for disc already and I can turn down the sprocket flange and mount it up front. It would be nice to have front and rear brakes on this thing
Actually all he needs are good brake shoes.
The factory brake shoes are pretty much junk. Make sure the drum is not rusty. If it is, use the old shoes and glue sand paper to them and just ride it a little while dragging the brakes to polish the drum. Simple cheap and a pain in the rear but it will clean the drum up. If you install the new shoes on a rusty drum then all the junk gets embedded in the new shoes and then they are junk...
A quick search of the forum turned up this....
https://www.oldminibikes.com/forum/index.php?threads/replacement-brake-shoes.21997/
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=06430-GBJ-J10&_sacat=0
Jockey
New Member
I ordered a set of shoes from amazon that are just like that. They come in today along with a tav2 and new tires.
