Compression release working?
I have a bigblock that rope started fine with the head cut .050 and 35# valve springs. It still has the same cam (.246 duration, .260 lift) with a compression release. I have a new head that I got cut .080 with the same thickness head gasket as before (.020) but has 55# valve springs, and 40/33mm valves and it's ported. I also put 1.2 ratio roller rockers on it but I can't rope start it now. I've adjusted the valves over and over for .003 to 0 lash with no change. I took the cam out and the compression release looks like it should work, it's measuring .070-.075 higher than the exhaust lobe. Am I doing something wrong or where should I start working?
Where is the piston when you are setting the valves? Should be a few degrees past TDC so you are for sure past the compression release.
I've tried it that way and didn't help. I bent the compression release up some and I'll put it back together in the morning to see if it helps, if not I'll go a different route.
