Correct kit?
I looked this carb up on the Tecumseh service parts list and come up with service #630813. I can't find this anywhere. All I can get is some sites mention it as a replacement for 630772. Can't find anything for that one either. Are some diaphragm carbs simply SOL for carb kits? I do have a kit for a totally different service number. If the diaphragm fits do i just go with that one? Or do I have a new paperweight?
Hey JT , I just got a rebuild kit from OldMiniBikes for my Hs40 with a #356 od16 carb
The OldMiniBikes #631893a , I havnt tried it yet but it looks identicle part by part
I will put it in today and give it a try
capguncowboy
The kit with a replacement needle, diaphragm, nut and seat is $7 on ebay.
http://pages.ebay.com/link/?nav=item.view&id=131359503165&alt=web
I just bought one two weeks ago to rebuild a diaphragm carb off a 70 Rupp
BTW the nut inside is 9/32. Be sure you pick up a socket if you dont already have one. I rounded mine off trying to use a 5/16 and had to drill it out. I do recommend the full kit so you can make sure the seat and needle is operating correctly
I'm willing to try but how would a person know that was the right kit without linking that service number to it?
I also haven't seen much difference with those carbs. Make sure you soak the 4 outside bolts and the main jet once you remove the cover.
