P Phosguy New Member May 17, 2017 #1 May 17, 2017 #1 Looking for a crankshaft for Tecumseh HS40 for my 1970 Rupp Roadster. Crank needs to be 3 inches on clutch side. Thanks
JohnnyTillotson May 19, 2017 #2 May 19, 2017 #2 Phosguy said: Looking for a crankshaft for Tecumseh HS40 for my 1970 Rupp Roadster. Crank needs to be 3 inches on clutch side. Thanks Click to expand... I have one but I would need to measure the PTO. It's all cleaned up since this pic BTW.
Rupp 72 Active Member May 19, 2017 #4 May 19, 2017 #4 JohnnyTillotson said: I have one but I would need to measure the PTO. It's all cleaned up since this pic BTW. Click to expand... Be careful, this crank is not for a ball bearing seal and may not be compatible with your side cover...
JohnnyTillotson May 21, 2017 #5 May 21, 2017 #5 Rupp 72 said: Be careful, this crank is not for a ball bearing seal and may not be compatible with your side cover... Click to expand... Yeah i dont think it is if thats what you have. I can check the wngine it came from too.
