I had a crazy but completely feasible idea about how to solve sea level rise. sea level rise is happening because more ice is melting from arctic glaciers than is being replaced. we cant easily fix the melting issue so that idea is out the window. to solve the problem we only have one other option: change the ratio of snow accumulation and melting so there is more snow is accumulating than what is melting each year. how to do this is expensive and not easy but is feasible. the solution is stupidly simple we just add more snow. to do this we build a desalination plant and series of heated pipes (heated to keep them from freezing in the arctic winter) powered by a nuclear power plant attached to a large number off snow making machines (the type ski resorts already use) placed on the glaciers that are melting and every day its cold enough to create snow we pump out thousands of gallons of water threw the snow makers. this over time will re build the glaciers and even un do sea level rise if its continued long enough. and every country that can afford to should pay a tax to help the project because this problem affects us all. I decided to post this to get this somewhat crazy idea out into the open and hopefully start some discussions. do with it what you will.
