Custom built Arco Colt.
Ok so as some folks have seen in my build thread the work that has gone into the building of this bike but here’s a rundown on it. Arco colt mini bike completely rebuilt. Not stock but very nice, it’s stretched on custom built tabs I modified from uncle larry’s mini bikes it also has hydraulic rear brake, and chain tensioner, the front frame has been welded solid no rear suspension, I also made frame gussets for the front near the steering tube, the front end is swapped for one from a Honda urban express so it now runs a Showa built front end with ball bearing steering, front wheel is a custom 10 inch wheel with Kenda 3.00x10 on the front, out back is a solid wheel and hub assembly with the brake disc and rear sprocket. Has a 145/70-6 Sunf tire on it. The engine is an electric start 212 lifan from gps, and it drives a standard centrifugal clutch. The battery is a 5lbs Napa powersports battery with plenty of power should one want to install lighting. The seat is from a Tomos moped and is new old stock modified to fit the frame. The frame is powder coated in mermaid candy from prismatic powders and looks fantastic.
Nothing on the bike has more than about an hours worth of run time on it. I can also include some other parts from the original bike and some spare parts as well.
Asking 1800obo located near Charlotte NC. IMG_0444.jpeg IMG_0445.jpeg IMG_0446.jpeg IMG_0447.jpeg IMG_0449.jpeg IMG_0450.jpeg IMG_0405.jpeg IMG_0393.jpeg IMG_0308.jpeg IMG_0306.jpeg IMG_0312.jpeg
