So we head up to Road Atlanta to race, along with the EVO, I took Evol Tweety Bird and Pure Evol to cruise the pits.
Unload and get ready to cruise around the place. Tweety who has run like a champ for what 2 years now, normally starts on the first pull. Not now, like she's gone bonkers, rips the pull start out of my hand, no matter where in the rotation I try and start her. Block the wheel get her to fire with the throttle open and as soon as you release the throttle she dies.
Just for info, 212 Hemi, billet flywheel/rod, no governor, rejetted, reported/ polished, Mod 2 cam, 22 pound springs, oil sensor delete, 3 angle valve job, custom header and air filter, dual breathers. VALVE LASH SET TO ZERO (0), both valves, cold.
What the heck! Pull the plug, and it's slightly rich like normal, but even with the plug out, it pulls hard. Aw crap!
Thinking maybe it sheared the key I disassemble her between rounds. Nope just fine. What the hello is going on?
Just in case, I drain the oil to check for metal, thinking maybe the compression release or spring had broken. No joy there, not a spec of steel or aluminum in it.
Finally pull the valve cover off and check the lash. Well that's odd, the exhaust is at 2 thos. Really? Could that be?
Well, checked the adjuster, it's tight, not moving. Okay, loosen it up and reset the lash to zero (0).
Put the cover back on, and she fires up on the first easy pull and sits there and idles like the little Harley she sounds like.
Really? That was it? REALLY? 2 stinking thousandth of an inch of valve lash made it do that? Seems so... ut:
I guess 2 years of running had loosened up things and opened up the lash enough to not hit the compression release. :facepalm:
