DB30 clutch noise
Hello all...new to these bikes, picked up a couple for the kids. I notice one sounds great, very smooth, and the other at idle the clutch is really pinging. What is it about the centrifugal clutch that would make one ping alot as compared to another identical one?
If the engine is angled the slightest bit to the left or right when mounted the clutch will ping like crazy, everything has to be dead on and lined up.
Thanks everyone!
The instructions are vague about chain adjustment. Though I understand the free-play method, they picture a chain without a tensioner, measuring the play on the bottom of the loop. I just removed the guard, and used the top of the loop to measure free-play. Is this how you guys are doing it?
I did blow out the clutch and oil it as recommended. I should put em on the bench and check the alignment though.
Thanks again for the tips.
Chad
