I wanna use the asuzalite 5" rims. Im wondering what regular sprocket that will adapt to these type rims not a drum. Basically im going to shim from the rim to a sprocket with some type of adaptor so i can use a caliper. Any help will be great. Thanks
Could you use a sprocket/drum on both sides of the wheel and use one side as the drive and cut off the sprocket teeth and frame mount your caliper around the cleaned off now disc. I guess the trick is the mounting of the wheel half's but it might be worth checking out. It's been years since I used the Azusa Lite wheels on a mini dune buggy,
Steve
