I got the 24 tooth sprocket installed on the jack shaft and re checked alignment, its perfect ...
That pic was taken after a short ride, the mounting plate was cleaned off and you can see where the new chain is chewing into the 3D Clutch sprocket and leaving a metal trail ..
Using delray's "how to start a hi compression motor without ripping out tendons" video [video=youtube;Di9nn2kSKp0]https://www.youtube.com/watch?v=Di9nn2kSKp0&feature=youtu.be[/video] I find this H50 Tec starts on the first pull!
I installed a Tiny Tach. It reads hours run when the motor is off and RMP when the motor is running.
The screen looks good, this pic makes it look hard to see through, it is not ...
I take it for a run ... the gearing is much better but maybe still too tall for me .. My neighbor had his late 60's Yamaha moped out and I paced him going down our street. My mini got to 6500 RMP and started starving for gas, I'm thinking I need to open the jet another step. The Yamaha said 27mph, that's about right ...
I have a sand hill on my block, I've ridden up and down it many times on many bikes. You can feel the torque going up it at a clip but it bogs to the point of stalling if you go up at 5 to 8 (?) mph ... I was able to ride the clutch and get it up the hill.
It has all the power of my old VT-10 and likely more if it was running closer to it's power band.
I was feeling a little frisky and did a rolling wheelie. I was going 5 MPH, pulled in the clutch, brought the revs up a bit, not a lot, dumped the clutch, the rest was slo-mo ....
The front end is coming up fast, the back tire is glued to the pavement pushing the bike forward, my clutch hand has not connected with the clutch grip, my 290lbs is not moving with the bike, I get unceremoniously deposited in the road as the bike goes a few feet on its back wheel as the front is coming down, it rolls another couple feet and falls over on its right side, runs for a couple seconds, stalls and starts leaking gas out of the Mikuni.
The happened in the space of 5 seconds tops ...
Ouch ...
