Front Rotor Hub Mock-up
Had some time this morning before going to a meeting at the university this afternoon (and on the road tomorrow and Friday ferrying mom to the docs), so I made up the mock-up for the front hub. Pictures are all wacky, again.:angry:
First, I needed to find the center of the head:
Then I used this locate center the wheel between the fork lowers.
And, used a piece of scrap aluminum to fix the width between the forks.
Wheel centered with a temporary spacer on the right (left front sitting on the bike).
I centered the Motovox disc on a 2 1/2" round piece of 1/4" modeling plywood.
I made up several more 1/4" round pieces to build out the rotor from the wheel.
Then I built it out to the caliper. The total width to the caliper is 1 3/8." Then, two more 1 1/2" diameter 1/4" rounds plus a washer serve as a spacer to the fork. The washer is just slightly thinner than the plywood.
Here's what it looks like off the bike:
From this, I can take measurements and do a CAD drawing. Do note I was using standard hole saws for these pieces and the final piece will have a center hub/spacer that matches the ID of the Motovox disc.
