Setting up a mini to run 125' drag. Here is the motor breakdown:
Predator Hemi, governor removed
ARC connecting rod, piston is flush with top of cylinder
ARC ultralight flywheel
Dyno Cam F275
stainless steel valves
ported and polished head, not a work of art, just smooth
Mikuni Carb 22mm, main jet about 140
Walbro fuel pump, fed in between carb and head
I am running a Comet series 30 torque converter
Yellow springs (3100 rpm) in driver
Yellow spring in driven.
I have extended the shaft on the driven unit to cross over as a jackshaft.
On the jackshaft 17 tooth sprocket
Rear sprocket 60 tooth
12" tire
The bike comes out of the hold nice, but at 125' I'm at 5100 rpm
Having trouble getting this figured out.
The carb is running great, checked different size mains and needle positions.
I'm sure I forgot something, any help is appreciated. I have attached a pic of the bike, older pic.
Dyno Cam F275
12" tire
