My TAV, a clone Comet 30 series needs a new belt. The belt is a Chinese copy and the marking are a little ambiguous leading to possibly buying the wrong replacement drive belt.
The belt is marked 162 through 165C which I believe is nothing other than a cut reference number, then "For Motor-Cycle Variable Drive" then the number 669 which I think is a good number. The worn belt appears to be 18 mm wide. The Outside Diameter of the belt is 26.75" long. (679.45 m/m) I'm sure it is stretched a little.
Are the 669-18-30 belts correct?
What brands are worth a crap? I have had good luck with Bates and Bando made belts in the past.
