I picked up a used Axis M200 (CT200U-EX rebrand) and everything is working well except the rear drum brake.
Riding it this past weekend and coming down a hill giving it a little bit of slowing brake the bike would grab, let go, grab, let go, etc.
Thought it might be the shoes so I grabbed a new set and just installed them. Cleaned up the inside of the housing with brake clean, greased the pivot points, greased the shaft etc. Same result
If I back out the ferrule on the end of the brake cable until it spins freely, I have very little braking power (and it still grabs and gives repeatedly). If I turn the ferrule in to get better braking power the wheel (off the ground in the garage) can be spun and then locks up, move it by hand and it'll loosen up again and repeat
What am I missing here?
