I had a little time today to do some work on my bird.
The frame was cracked at the rear of the motor plate and was welded before also somebody scalloped the tubing pretty bad when they cut off the friction brake tabs on both sides.So I hate hacked up stuff so I cut out the lower frame rails and put in 2 pieces of .058 c/m tubing.
There is no way i'm mounting the flat plate to these new pieces so I need to come up with a indirect type of mount,maybe weld angle to the rails then bolt the plate?
Any suggestions? :shrug:
