Hi Everyone,
Got a little bit of an arms race going between my brothers and I in regards to our minibikes. I'm looking to add squeeze some more power out of my Hemi Predator (current set up listed below). Does anyone run a hemi predator with a Dyno 308 cam?
Mikuni 22mm carb (130 main, 125 pilot)
ARC billet rod +0.020
ARC billet fly wheel (6602-PH)
NR racing .252-611 cam
Stainless steel valves (stock sizes) + Aluminum Retainers
26lb valve springs
Chromoly push rods
I'm looking at
Dyno .308 cam
ARC - 6168 dual valve springs and retainers
Amateur porting (just clean it up a bit)
I'll have to enlarge the spring pocket diameter and possibly clearance the block or crank (which I don't mind doing), but I'm wondering how much lift I could get before coil bind? This combo would yield .320" valve lift I believe, and I've read that the hemi installed heights are shorter than the other clones.
I'd appreciate learning from some others experiences before making the investment, if possible.
26lb valve springs
Chromoly push rods
I'm looking at
Dyno .308 cam
