The decision to use OHH valves resulted in other challengees. They are quite a bit longer than the valves in the OVRM heads, but the plus was I could use OHH pushrods. The OHH are much bigger and beefier than the OVRM pushrods. The longer valves created the condition having too much little of and install height to having way too much.
This also of course completely changed the height of the rocker shaft.
To make this work, I had to machine billet aluminum valve spacers to achieve the correct .900" install height and I had to machine a new yoke for the rocker shaft system. When I made the yoke, I moved the bolt holes to the correct spacing and moved the fulcrum shaft forward .030" to center the rocker over the valve. This was a lot of trial and error, but I eventually ended up with the perfect geometry.
Here's pics of the spacers and the yoke that I machined for the rockers.
